kioti dk40se will not turn over
   / kioti dk40se will not turn over
Well I got to drag my tractor all over my property yesterday.
I put it in high range 2 gear. The tires on the tractor would not
Turn. I then went to 3 gear the tires would turn. I drug it about five hundred
Yards with no luck. This tractor only has around 70 hrs on it. I really do not
Want to split it if I can avoid it. I also engage the front differential. Any ideas?
Should I start a new thread (clutch will not disengage)?
   / kioti dk40se will not turn over #22
Maybe a dumb question but, you did have the clutch pedal locked down, yes?
A new thread with a more precise title is a good idea.
Yes the clutch pedal was down.
I moved this post to a new thread(Dk40se stuck clutch)
   / kioti dk40se will not turn over #25
Drive tractor, get it good and hot. Then block the clutch pedal down. Let it sit overnight. Then do it again.
Alot of times the dissimilar materials will allow the clutch and flywheel to separate.
You have an extreme circumstance that is for sure.
You also might want to take the starter back off and aim a heater at the hole in the bellhousing so you can make sure it is dry.
Leave clutch blocked down while doing this.
2017 Chevrolet Impala (A56859)
2017 Chevrolet...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
2020 Hyundai Santa Fe (A56859)
2020 Hyundai Santa...
2013 Yale Forklift (A56435)
2013 Yale Forklift...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Yamaha (A55758)
Yamaha (A55758)
