Kioti vs. Bobcat prices
   / Kioti vs. Bobcat prices #31
There is a Bobcat dealer near State College that I go past quite often, one of these days I am going to stop and take a look at the tractors they have sitting in front of their store.
The pictures that Wallace posted some time ago show them coming off the same assembly line as the Kiotis.
   / Kioti vs. Bobcat prices #32
jcims said:
(Off topic, i saw the DK35 in person for the first time last night...didn't get to drive it, but i really liked the size and setup...definitely still at the top of the shortlist)
The DK35se is very similar to the DK40se and 45se. Other than a few horsepower and bigger rear axle, the major difference I could find was that the 40/45 have a much more powerful loader. If your work is loader intensive the 40/45 have advantages. There is not a huge leap in price from the 35 to 40 so keep that in mind.
   / Kioti vs. Bobcat prices #33
Thanks for the note. They had the DK45 there, which i thought was probably too big for what i'm going to do, but i am going to try to take a look at the DK40 before long. Agreed it's a good deal if you can use it.
   / Kioti vs. Bobcat prices #34
As best I can tell the main differences between the new DK35 and 40 are not really in the horse power...38 vs 41. What is different are the axles (someone mentioned the DK35 shares rear axle at least with the CK35) and most important for me at least is the difference in capacity between the KL351 and KL401 loaders (for the DK35 and 40/45 respectively).
For clearing brush, breakout capacity and rollback force are important numbers as it gives you and idea of what size tree/bush you can just pop out of the ground with bucket or grapple rather than needing to cut them down and dig out the stump. Popping them out obviously takes virtually no time (knock it over, expose the roots, stick the grapple underneath and curl/lift...pop and you are done and on your way to the burn pile never breaking a sweat, getting off your seat or risking life and limb). The alternative of cutting it down then digging out the stump takes 30 extra minutes at least and means you actually have to do some work. The KL351 has breakout capacity of 2640lbs and rollback force of 2760lbs while the KL401 can do 3720lbs and 4600lbs respectively. Total lift capacity is also quite different (1400 vs 2700lbs). I don't know why there is such a big difference between the two when the DK35 and 40/45 are part of the same series and not so very different in horsepower but the fact remains.
   / Kioti vs. Bobcat prices #35
Gahhh...i think the slippery slope has claimed another victim. haha Guess i need to send another email to Jeff at Brownie's :)
   / Kioti vs. Bobcat prices #36
The CK and DK are different chassis. The DK35 is a 38HP 3 cylinder engine, the DK40 is a 4 cylinder, tires sizes are different, and has been posted, the KL401 loader on the DK40se is quite a bit stronger than the KL351 on the DK35se... The DK35Se is a significant upgrade from the CK35 and the DK35SE bridges the gap between the CK35 and DK40SE as the 40 seems to some to be getting into a larger class of tractor, not as "compact" but still not quite "utility" in size.
I just learned today that Bobcat is adding a 22hp tractor to their line. Basically the same as a CT120, it is called the CT122 and has a 22hp 61.6cu in engine. The price I was quoted, including a loader is $14,042. That, I was told, is $500 more that the CT120. The price I was told in December was probably a ball park figure which they gave out at their open house.
I was pretty well set on the Kioti CK20 hst because of the price difference then. However, since the price is now much closer and the Bobcat dealer is only five miles from where we will be building, my mind seems to liking white paint a lot better (it does have orange wheels, though).
I will add pics when I finally make a purchase.
Fuddman
   / Kioti vs. Bobcat prices #38
Isn't that essentially just a CK20S?
   / Kioti vs. Bobcat prices #39
Sure sounds like it to me! Guess BobCat got tired of trying to sell the old tractors and decided to upgrade to the new ones. :)
It is essentially a CK20S HST, with changes that Bobcat specified which includes a loader from a different manufacturer. There are, I was told, 133 changes based on the Kioti warranty records that the Bobcat people studied.
I think either of the two brands will serve me well. It is only a question of the closer dealer which also has a good reputation in the area.
Fuddman
2006 Land Rover Range Rover Sport 4x4 SUV (A48082)
2006 Land Rover...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2011 Honda Odyssey Mini Van (A50860)
2011 Honda Odyssey...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2004 Chevrolet Venture Mini Van (A50860)
2004 Chevrolet...
