Kohler Command Pro 25 blowing smoke at start up
   / Kohler Command Pro 25 blowing smoke at start up #11
another sign of guides is ... if you let it sit for awhile ( 30 mins or so ) and start it back up and it blows blue smoke, you've got guide problems
if you don't get any smoke restarting after letting it sit ... it is probably rings
both are moot at this point ... to fix either problem will require a tear down and rebuild anyway ....:(
so just keep the oil level up , change it at regular intervals , and keep using it till you are ready to do a proper fix .....
(or just keep your eyes open for another good motor that will pop up sometime, )
Thanks jaotguy
After doing some research, worn valve guides are the probable cause of the blue smoke at start up.
The zero turn has 850 hours on it.
   / Kohler Command Pro 25 blowing smoke at start up #13
With 850 hours, most likely the oil is seeping past the rings on the vertical shaft engine when it sets, and is getting burned off when you start it. Unless it is using a fair amount of oil during use, or starts smoking continuously I wouldn't worry about it.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
2015 GENIE 2X-135 / 70 ARTICULATING MAN LIFT (A52707)
2015 GENIE 2X-135...
John Deere RSX860i (A56469)
John Deere RSX860i...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
2018 CATERPILLAR...
