Kohler Magnum 20 Cylinders interchangable?
   / Kohler Magnum 20 Cylinders interchangable? #1
defranks
Crab Orchard, TN
Branson 4220
This is a question without a lot of background, but the group here is pretty knowlegable, and I hope one of you can help.
I have a Vermeer 620 chipper powered by a 20 hp Kohler Magnum engine. The engine label is completely worn away from the engine, so I have no clue what the spec is, and there is no specific information anywhere on the chipper frame, either. I know it's a Kohler Magnum 20 hp based on labeling on the air cleaner, but that's about it.
The engine starts and runs, but it lacks power and it burns a LOT of oil. I think the bottom end is just fine, but it needs pistons and rings.
A seller on eBay has a pair of cylinders complete with pistons (used) for a fairly reasonable price. I know that Kohler had different engine specs depending upon application, and some of that includes crank length, etc. But what I don't know is whether all the cylinders will interchange. If they will, then I can probably just buy these cylinders and swap them out.
Any advice?
And yes, I've considered that the cylinders I am considering could be just as worn as those I have... but I doubt it!
Thanks!
   / Kohler Magnum 20 Cylinders interchangable? #3
SuperXPower.com is a good site to look up parts,and compare what fits what. They show parts breakdowns and show vermeer used M20-49553 engine.
TOFT CAT315 HD 45" Excavator  Bucket (A49251)
TOFT CAT315 HD 45"...
Smith 75 Air Compressor (A49251)
Smith 75 Air...
2019 John Deere 4052M Tractor (A49339)
2019 John Deere...
Farmall M 2WD Tractor (A49251)
Farmall M 2WD...
2012 KENWORTH T800 (A48992)
2012 KENWORTH T800...
10ft QA Snow Pusher (A49251)
10ft QA Snow...
