namesray
Platinum Member
my b7800 has 880 hours on it now. since last fall it has started starting rough. just the first start of the day. all other days starts it fires up like normal. warmer weather here now and it is starting up better, but still not right.
the manuel says to have the "engine valve clearance adjusted" every 800 hours. my dealer said this might be the solution to my problem. i got a price guestimate from them and after talking to them, i wanted to ask everyone here as well, is doing the engine valve clearance adjustment worth it? who here has done it? do you reccommend doing it or not? dealer said most of the ones they did still were within tolerances even over 1000 hours. cost range is around $350. i do not believe i could do it myself and really don't want to attempt it.
if it means anything, when temp is below 50*f. i glow plug it for 15 sec. tractors always starts, but sputters for about 5 sec and spits smoke for the time it is sputtering. then seems to run fine. all other starts that day start good. it never did this until last fall. 6 years old. thank you for your opinions.
