kubota b2630 drive shaft
   / kubota b2630 drive shaft #1
nrockow
Upstate New York
Kubota B2630
Recently while cleaning up some overgrown areas around a storage shed, I had some heavy gauge wire wrap around my drive shaft (actually it was a tomato cage - how it got in there is a true mystery). It took several hours of pulling and unraveling to get it out, but it is out. After removal of the wire and inspection of the shaft, there seems to be a small amount of turn out while the shaft is turning (engine running). Does any one know what the tolerance is for this? A machinist friend of mine says that it seems slight for a shaft of this lenght (estimated at 5 - 10 thousanths of an inch) and that the bearing in each shaft coupler will have some play to account for any misalignment between the engine and transmission. I just want to make sure that I don't do any long term damage to the machine by running it with a shaft that is out of true. Thanks for the info.
   / kubota b2630 drive shaft #3
Prefect is nice but will rarely happen when you have multiple parts in any assembly. With 5 to 10 thousands run out you will never be aware of it… you could have ten times that run out and not cause yourself a problem…
I see this is your first post, Welcome to TBN … KennyV.
   / kubota b2630 drive shaft #4
Thanks for the encouragement. I'm sure it is new tractor paranoia! Just seems to have a little more vibration than before...like I said...probably just paranoia. Thanks for the welcome...this is a great resource.
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2015 FREIGHTLINER M2 24FT BOX TRUCK (A56138)
2015 FREIGHTLINER...
