Kcu320
- Joined
- Oct 8, 2021
- Messages
- 2
- Location
- Stafford, Virginia
- Tractor
- 1985 John Deere 318; 1984 Massey Ferguson 1855
New member…I just joined. I have a question that could have been posed in either the projects or Kubota. I chose Kubota. I am modifying my John Deere 318 to receive the D600 Diesel engine. On the donor tractor, the Kubota G5200, the engine was placed in backwards; I.e. the water pump was closest to the operating station and then the fan and radiator. Cub Cadet also used the Kubota D600B in their 782d and a couple others. I’ll stick with 782d for this question. In the 782d the engine is faced in the opposite direction as the Kubota G5200; meaning, the radiator, fan and water pump are at the extreme end or front of the tractor (like a car/truck). So, not thinking, I thought I would set my tractor up like the Cub Cadet 782d. The mounts we made fit nice, I didn’t have as much notching to do of the frame, etc. Just as we were about to weld in the mounts my friend said “WAIT!”. We discussed which direction the engine rotated. So here we are two grown men walking around the tractor waving our fingers in the air in circles mimicking the direction the engine turns the shaft to the hydro. We discovered that the engine could only work if we undid our work and placed it back 180 degrees from the way we had it; in other words, like we had it in the beginning. So we had to make new engine mounts, cut mounting brackets off the engine, etc. We were set back a whole day of fabricating.
My question is: do you think the “B” in the D600B was a special made counter-rotating engine made special for Cub Cadet? I haven’t been able to discover any info on that. I have several D600 manuals but no D600B. Also, we figured you can’t run a hydro the opposite way because you have a non-pressure side and a pressure side. Did we make a mountain out of a mole hill or was it a save at the last possible second? Thanks for sticking with the story and helping me understand if I made the right call or not.
