Kubota L2900 drive clutch problem
   #1
BertZegers
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
The tractor is a Kubota L2900 with FEL and Cab. 1802 hrs
The problem with the clutch is;
It depresses and disengages fine but when the clutch pedal is released, the clutch does not engage with the travel of the pedal.
The clutch kind of "stays behind" and then suddenly engages.
If I work the pedal a few times it seems to be better.
Is there a inspection opening to see of the release bearing "sticks"
The tractor has the independant PTO clutch witch is working fine.
Thanks for your replies.
