cletus
Hi Guys, Have long appreciated this forum for all the great knowledge. My ever-reliable L310 wouldn't start after I'd been working for a few hours.
Pulled my car battery and it started and i got it back to the shed. Got a new battery and had to also get a new positive battery connector. Took off positive cable to replace the connector, reattached. Cleaned the single wire clip-on connector that goes to the main fuse box. Now I have all dash lights and when the glow plug goes out, only get a click. Cleaned ground strap. New battery measures about 12.4 volts on battery itself and on battery cables. Bypassed ground cable with jumper cable and no change. Checked seat safety switch and it has continuity. Have jiggled PTO and shift lever. DId measure voltage at positive starter connector when key is turned and it drops to 11.47. Haven't bypassed positive cable yet. Any other ideas? I'm thinking since all was fine till I replaced the battery and removed/replaced the positive cable that i must have messed up something or else the new battery is bad. Battery is Die-Hard gold from Advance, 750 cca. Thank you all!, cleatus
