Kubota tires
   / Kubota tires #1
MrBwill
2003 BX23 Kubota
I purchased new tires and wheels from a dealer in Butler Pa for my BX23 a few months back. Originally my front tires were 8 inch tires/rims but the new ones for the front came in as 10 inch, which I guess is the route Kubota is going when replacing tires. Once I mounted the front tires I have been in a constant struggle to keep air in the tires. In checking, there is no inner tube available for these 10 inch tires, either from Kubota or anywhere I could find. Since it is over 90 days since I purchased the tires and rims ( I waited a few months before mounting them) the dealer just shrugs his shoulders saying" there is nothing I can do because you went past 90 days." I am not looking for a refund, just a solution but no help at all from the dealer. any suggestions?
   / Kubota tires #4
Are the new tires the same circumference as the old ones?
I'll also second the suggestion to dump that dealer - it's good advice.
Try contacting Messicks - I get most of my parts from them - they have been very helpful & knowledgeable.
   / Kubota tires #5
I'd check with Agri Supply. A tube size isn't anywhere near as critical as a tire size for a particular wheel. You can get something close and still be ok. A 6x12 tube might do ya and if worse comes to worse, you can fill them with foam.
   / Kubota tires #6
Agri Supply does have a 10" tube.
   / Kubota tires #7
Where are they leaking from is it at the bead and rim or where. bead sealer or flat repair may help
   / Kubota tires #8
This is a real backyard solution, but pour boiled linseed oil into them, then air them up. It helps to slosh the tire so the inners all get coated. I used 1/4 can per wheelbarrow tire, you may need to use 1/2 can per tire. After hearing about it, I tried it 3 times and it worked great each time.
   / Kubota tires #9
The fronts were no longer available for my BX and Kubota had substituted a different style.
They work ok but had the same issue.
I used Slime and no problems since.
   / Kubota tires #10
You should try and use liquitube, that stuff fills up to 1/4 holes and it is specially made for low mile an hour vehicles like tractors. Me and my dad had a problem with our front tires of our bx and took it to the dealer and they fills the front tires with liquitube in both of them and it's been 6 months or more and we haven't had a leak in them yet. I've read online that liquitube doesn't freeze until about -43 degrees F. That should fix your tire problem, you might want to have the dealer do it though.
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
Trailer Mounted Light Plant (A50860)
Trailer Mounted...
2011 Land Rover Range Rover Sport AWD SUV (A48082)
2011 Land Rover...
tiller (A50860)
tiller (A50860)
2019 POLARIS XP1000 RANGER (A51222)
2019 POLARIS...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
