Dirt Moving Kubzilla 2, And so it begins...
   / Kubzilla 2, And so it begins...
That's a good point, and a very clever way to address the problem. I would have to make it easy to remove though, because I use the Backhoe frequently. I'm finding that the biggest problem here is the frozen ground. I thought I was hitting rock, but it turned out to be frozen dirt. I didn't have to deal with that in Texas...Oh well, when you don't have size, it's all about technique!;)
   / Kubzilla 2, And so it begins... #12
Frozen ground, man I can't even imagine. I'm near Houston (25 miles SW) so even when we get freezing temps it is usually just for a few hours overnight. Coldest I've ever experienced was about 5 above and that was in Colorado.
Now, I would love the wide open wilderness you have up there at your new place.
BTW, using the hose clamps like I did, you could probably remove the horse panel in about 5 minutes or less. I can't take any pictures right now because my tractor is out at my weekend place 48 miles away. I thought about welding some hooks to the ROP. Something along the lines of small chain hooks, 2 on each side and one at the top, with all the openings facing up. That way a person could just drop the panel into place. I didn't think it would be worth the trouble for me since I won't be removing mine that often. Maybe you could do something along those lines since you have a BH.
   / Kubzilla 2, And so it begins... #13
Congratulations on the BX25! :thumbsup: One thing i am wondering is since you are working in the woods do you have anything protecting the hydrostatic fan under your Bota? My neighbor's BX24 had its fan destroyed from a branch so I am curious what you have done to protect your fan, that is assuming that the BX25 has one. It is a $10 fan and a $600 fix. :(
If you do get a chance to take a picture, I would love to see it. Thanks!
Ouch, that pic looks painful... I haven't given it much thought, but you make a good point. I suppose a skid plate maybe? Yea, there's a bunch of small trees and scrubby things here to cause problems...Thanks for that info.
   / Kubzilla 2, And so it begins... #16
Welcome back & congrats on the BX25! :thumbsup: How did you take that picture? :confused2:
   / Kubzilla 2, And so it begins... #17
The best one i have found is the Bro Tek skid plates. :thumbsup:
Thanks. It was taken from our second floor balcony. There are some very nice and dramatic snow covered mountains in the background, about 3 miles away, but for some reason, they were washed out in the pic and didn't show up...:confused:
2013 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A52707)
2013 CATERPILLAR...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
HOMEMADE HEAVY DUTY FIRE PIT RING, ORANGE (A57192)
HOMEMADE HEAVY...
