L2800 3 point shudder problem
   / L2800 3 point shudder problem #11
I had my L3400HST replaced last spring. The dealer had never heard of it, he did some research and fixed it no charge. A guy I work with had his L2800HST fixed last week in Alabama, no charge.
Thanks to all so far , keep them coming .
Just curious is there a way to start a Poll within a post ?
   / L2800 3 point shudder problem #13
My dealer replaced the valve on my L3400DT after I bought it. Works better now but still not silky smooth.
Bump , TT
   / L2800 3 point shudder problem #15
I bought my L3400HST in April 06. I was ticked off to find the problem because I had advised them of this issue when I made the purchase.
Heck I pointed it out on the L2800HST I test drove on their lot.
I double checked when they said they were ready to deliver and they said - "yes your tractor came with the fix from the factory".
Tractor gets delivered and a day after I realise - heck this thing is shuddering like crazy!. Gave them heck. They got a Kubota rep to my farm. He knew all about the problem and had a printout about it.
He claimed that I should have had the new valve from the factory but it didn't look like I did. They took it in and got me the valve.
The Kubota rep. did claim that this was an "economy" tractor and so they were not obliged to fix it but since I had asked for the fix before purchasing it it would be done. Glad I didn't have to beat them over the head for it.
The valve is MUCH smoother now. I imagine it is not as good as the Grand L valves... it still seems to move in discrete increments - probably 1/4" if you ask me but not 1" like it did on the old valve.
Other than issue - I've had no trouble with the tractor.
   / L2800 3 point shudder problem #16
Whenever they say "Economy" about the L2800 and L3400 is really burns my *#@&. We paid good money for these tractors and expecting that the 3pt and the pto's work properly is not unrealistic. Heck, I still think they are pretty nice. My tractor and a couple implements cost more than my last new car and everything on it works just great. Honda Accord if it matters.
Just had to vent a little. Brian
   / L2800 3 point shudder problem #17
Glad to hear that my L2800 isn't the only one with this problem. I bought it with 23hrs on it and while test driving it on the lot without an implement behind it, PTO raised and lowered just fine. Once I got it home and hooked up to my Land Pride 72" finish mower the sheddering was happening. Thanks to you guys I reaserched this problem on this site, went to the dealer and told them about this and they were aware of the problem. Told me to bring it in next week before I go on vacation and it would be ready by the time I get back. Also told them about my light switch that seems to be shorting out. Again, dealer tells me that they will fix it all under the mfg warranty. Will let you know how it goes.
   / L2800 3 point shudder problem #18
Same here!.. on both fronts. Drives me nuts when they say 'economy' and mine cost more than my last new car (also Honda Accord).
To be honest I still think this is a great machine and the best value in this size. Will chat on the other thread about the PTO issue. I've been doing some thinking after reading that thread and after my first initial response. I have a feeling that the PTO worries have been amplified wrt. the over running clutch. I cannot believe that Kubota did not do 100s of hours of testing with this PTO design and various implements like tillers. It may be that the newer design is better but that does not necessarily mean that the older design is just an impending failure. I strongly suspect that the OP on that thread just got a lemon - which unfortunately happens from time to time.
Can someone who has had the valve replaced and has a Invoice from the Dealer tell me what they list the repair as ?
Thanks GM
   / L2800 3 point shudder problem #20
I had the valve replaced but I can't find the repair order. The dealer seemed to have no problem getting the valve and installing it. It is night/day between the two. The first job I ever did with my tractor was post holes. As you could imagine a jerky 3pt. and loose dirt on an auger bit does not make a very good hole. I really don't understand how these tractors went out the door that way and then did so for so long. It even was a pain to use a box scraper. I will look again for the repair order. I know I have it or maybe someone else does. Brian
UNUSED FUTURE...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
43024 (A59228)
43024 (A59228)
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
