tracecom
Bronze Member
I changed the hydraulic fluid as part of the 600 hour service, and then used the tractor to bush hog for about 4 hours with no problems. Put the tractor in the barn for the night last night. Went to start the tractor today, and it will not turn over. The dash lights up as usual, the glow plug indicator lights and goes out. I turn the key to start and the starter doesn't run. The battery is fully charged. The shuttle selector is in neutral. The PTO is off. The parking brake is set. The clutch is depressed. I try again but starter doesn't run. I reset the wrench light on the dash, and try again. Nothing. I disconnect, wait 70 seconds, and reconnect the battery. Nothing. I try again, and the wrench light is on again. I fumble with resetting it and the dash lights the Service Inspect warning and the A of the ABCDEFG section is flashing. I am baffled.
What next? Thanks.
What next? Thanks.
