Rotary Cutter Land Pride vs. Bush Hog Rotary Mower
   / Land Pride vs. Bush Hog Rotary Mower #1
Buster57
Platinum Member
Hillsboro, Oregon
B7800, JD RX95
I am presently evaluating a Bush Hog Squealer 60” rotary mower as well as a Land Pride 18 series version
Both have slip clutches. I will be using on a Kubota B7800 on frequently mowed pasture grass.
The Bush Hog is about $200 less expensive. Roughly $1300 vs $1100.
Does anyone have experience with both of these units? I had a LP 1560 and beat it to death-but that was probably due to me and not the mower’s fault :)
I suspect that both are very good commercial mower decks.
Thank you!
   / Land Pride vs. Bush Hog Rotary Mower #2
I'm not 100% familiar with the Land Pride but I will say that the Squealer is an extremely well built cutter and should be able to withstand most anything you throw at it.
   / Land Pride vs. Bush Hog Rotary Mower #3
I have a Bushhog SQ600. I'd tear up my tractor before the Bushhog. The cutter has seen some mean stuff. If it's not a tree and I can push it over with the FEL, it'll cut it.
Everything I've seen by LP is very comparable to BH. I just purchased a LP RFM model FDR 1672. I've had it 2 days and it's 40 degrees so haven't really used it yet. Not really apples to apples comparison but from quality of production on units I own, I wouldn't hesitate to buy either.
My case was exact opposite, BH RFM was $400 more than LP. If money is the kicker, I'd get the lower priced of the 2.
   / Land Pride vs. Bush Hog Rotary Mower #4
I agree, pretty equivilent well built units from two top end companies
buy the cheaper one, don't sweat it
2019 John Deere 310L EP 4WD Backhoe (A53485)
2019 John Deere...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
