jenkinsph
Super Star Member
I have not hit anything not intended yet with the BX 25 however with an earlier BX that I had a middle mower on I was too lazy to remove the front loader and while mowing quickly took out a metal fence post. Your aerator looks lighter than the one I am getting. As I may have posted the one I'm getting is 36 inches wide and weighs 650 lbs so I don't have to add any weight. The removable spoons are mounted on approximately 2 inch wide laminated plate steel wheels which rotate on a single axle. Unlike the plugger aerators that the spoon/spikes are permanently mounted on a roller drum, the set up I'm getting should not compact the soil as you try and loosen it.
The compaction he is referring to is the heavier tractor tires on a B, not the aerator. About your new unit hopefully Ted and EA hit a home run on their design.
