Well the first question is what is the range of the torque wrench? Is 108 near full scale or only 10-20% of full scale? The recommendation is typically to unload them to less than 10 or 20%, so if that is where you left it, don't give it a second thought. If you really want to get it calibrated, you can send away for it, and it will cost a bit and probably take a couple weeks. There may be a resource listed in the manual if you still have it. Or search online. Seeing as you are listed as being in Anytown Ohio, I would expect you could find a localish source in Cleveland, Columbus or Toledo areas, whatever is near.
The other thing you can do is test it yourself. Torque is a bit unique in that with a decent fish-type scale, you can get pretty close. Torque = force times distance of the arm. Set the torque wrench for some value that make sense for this bolt. Grab it with the torque wrench and put a fish scale at the free end. Measure from the center of bolt to the point you hook onto the wrench in inches. Pull on the fish scale to tighten the bolt and watch the force on the fish scale. Pick off the max force just before the wrench pops. Multiply inches times force (lbs) to get the torque your fish scale measured. How close is it to the torque wrench setting? This is how you calibrate. The labs do the same thing, but with better precision and control. But you can at least look to see if you are even close this way.
