License a homemade trailer
   / License a homemade trailer #11
If this was a camper should it already be titled as a trailer?
Here in VA a homemade trailer is one made from scratch..
Just curious
Brian
Not in NY Brian, just by changing the intended use of the trailer (camper to utility) also changes weight, the state sees it as a new build. That was my thought when I started the project. Now I am finding that I need to show receipts for materials and any add ons including the paint I use.
   / License a homemade trailer #13
Excellent! You shouldn't have any trouble with the design or workmanship, you just gotta find the right person to talk to at the DMV.
   / License a homemade trailer #14
Casey: when I registered mine I didn't have any receipts except for some incidentals like nuts and bolts, paint and some chain. I told them that the rest was made from stuff I had at home.
   / License a homemade trailer #15
Another thought (better one this time I hope).. Check with a local salvage yard/body shop that rebuilds cars for the name of their DMV contact OR find out when the DMV person is going to be at the salvage yard to inspect vehicles and take your trailer to them..
Here in VA we have DMV agents that pretty much only do salvage inspections (determine whether it is salvage only, must have branded title, or clean title, title homemade builds, and titles inspections ) every day.. they practically live at salvage yards/body shops
Good luck
Brian
   / License a homemade trailer #16
This is so they can make sure tax was paid on the parts......
In PA, it is all done in the mail. There is a form that you fill out and get signed by a trailer inspection mechanic and you send it in with pictures. I was told that half the time, they bounce them back and that the pictures better clearly show the safety chains and all lights!
Ken
   / License a homemade trailer #17
I think you guys have it rough! Here, you just go weigh it, and if it is below 2K, they give you a tag. If it is over 2K, then it has to be assigned a VIN # and then you get a tag. A couple of trips around town, and your done.
David from jax
   / License a homemade trailer #18
casey lb1914 said:
Has anyone from NYS experienced getting a homemade trailer over a 1000# licensed ? I stripped a camper trailer off the frame and put on a deck, it is a 6x16 tandem axle w/elec. brakes now I need to get it on the road. I know the state needs to inspect it also the DOT. Iam close to Rochester. I have called DMV but as always, thats like pulling teeth to get an answer, where do I go for the DOT inspection. I will post my pics when I get a chance.
I built one a few years ago using MH axles but had to replace the tires with DOT approved trailer tires. Its been over 10 years so rules may have changed, I'm sure fees did.
1) My local DMV was helpful and told me I had to go through Albany for an application for title and gave me Ph# to call. I called Albany and told them I was building a homemade trailer and was going to register it for 6K even though I was using 2 6K axles. They sent me an application.
2) Once built I had to make copies of all materials purchased showing I paid sales tax. If not they will make you pay sales tax based on their estimate. Also had to go have it weighed empty and get a certified copy of the weigh slip to send in with application. The local dump has a certified scale and didn't charge me to weigh it.
3) Send application with copies showing you paid sales tax on materials (mainly axles, tires and steel I bought) and the fee (I think it was $25.00 at the time) and weigh slip to Albany. I know title fees have gone up now. $50 just for title.
4) Albany scheduled an appointment to take trailer to DMV to inspect. (My closest office for this was on Taft Rd. Syracuse) The inspector checked my frame and welds, tires, lights, and a brake test, Then affixed a VIN# decal to my frame.
A few weeks later I got a title for the trailer showing it as a custom built.
I don't think I would do it again since it is a hassle and time consuming.
Out of curiousity, don't you have a title / registration for the camper you stripped? Or if not get a pencil tracing of the VIN on the frame and apply for a lost title / registration. It would be much easier doing that.
By the way you did a great job converting from your pics.
   / License a homemade trailer #19
Here in Nebr, all I have to tell them is the size of the trailer and weight rating of the axle for a homemade trailer. Nobody even looks at it. Even factory trailers can be liscensed as an untitled trailer. Many people buy a factory titled trailer and don't even want to spend the $10 to transfer the title and just use them as untitled trailers. If I buy an untitled trailer, I just liscense it again as untitled without any questions. If you have the trailer model, company name and VIN, they will just put in information on the trailer liscense but can still call it untitled.
   / License a homemade trailer #20
I'm gonna guess that the one in the background is your next project and will also be torn down into another tractor-haulin trailer ??? ;)
2004 JLG 660 SJ 60 Ft Articulating Boom Lift (A59213)
2004 JLG 660 SJ 60...
7021 (A55851)
7021 (A55851)
TANK MANIFOLD (A55745)
2021 ISUZU NPR (A58214)
2021 ISUZU NPR...
Honda Pioneer 700 4x4 Utility Cart (A56857)
Honda Pioneer 700...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
