Diggin It
Super Star Member
So buy one and measure it.
Then do the same with generics.
Basically other boards like this. JD is said to use a steeper angle. Something like 32 degrees instead of 36-40.
View attachment 654572View attachment 654573View attachment 654574View attachment 654575
I had a problem with my X300 mower deck belt breaking, so rather than cut the threads shorter on the adjusting rod, I installed the bracket on the outside. It's currently installed on the inside and it's too close to the belt. This is the grass shoot side of the mower deck.
I removed the bracket, ground the weld and removed the existing pin, and welded on a new (longer) pin to the bracket, and reassembled. This allowed the threaded adjusting rod to be installed on the outside of the bracket, nowhere near the belt. Works great now. all I used was 1/2" dia rod x 2" long and a small piece of flat bar 1-1/8 long x 1/2 wide x 1/8 thick. I attached pics. Now I use a $20 kevlar belt from Ebay with no problems.
The JD branded belts are junk. Very short life from the one I bought ... ONE. Never again. I switched to the blue Kevlar belts for $20 or so. To be fair, I ate one of those too, but my deck has more hours than most - just over 1,000 now.
D&D Powerdrive or Jason are two I've tried for different machines.
JD part number should be M154621; search that and add kevlar ( M154621 Kevlar ) and you should find some options. Should be a 1/2" x 146".
