A friend has a Long 2360 that is blowing the number 2 fuse (charging circuit). A couple questions what are the fuse sizes for all the fuses. The operators manual does not list size.
It is felt a wire under dash is the cause as a mouse nest was found under there. It looks like the only way to remove the dash is to remove the steering wheel. Is there another way to remove the dash and if so how? Any other suggestions as to why the fuses would be blowing? The wiring under the hood looks good. The charging relay tested ok.
I have attached a wiring diagram.
