Long 360 tractor with hydraulic oil in the engine???
   / Long 360 tractor with hydraulic oil in the engine??? #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I noticed the hydraulic oil low. checked the engine and the oil was at the top of the stick!
The only thing I can see that is common to the two is the hydraulic pump mounted to the engine.Anyone have this happen before? the fix?
   / Long 360 tractor with hydraulic oil in the engine??? #2
Remove and replace front seal on pump ,if shaft is bad use a speedy sleeve,also check for any cracks in alum.front cover.
where would I find a seal for this?
is it a standard seal that I would find at a bearing supply?
   / Long 360 tractor with hydraulic oil in the engine??? #4
I have gotten them at bearing house's.
20 Gallon Air Compressor (A50860)
20 Gallon Air...
Toyota 8FGCU15 Forklift (A50860)
Toyota 8FGCU15...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
