Looking for a Harbor Freight Pump Gas Cap
   / Looking for a Harbor Freight Pump Gas Cap #1
Travelover
Elite Member
Washington
B7100
I've got a 3" gas water pump from Harbor Freight. Unfortunately, the gas cap vibrated off and landed on the engine. I arrived to find a melted plastic pancake. An email to HF was met with a "Sorry, parts no longer available" message.
The OD of the threads on the gas tank are about 2 1/4". A generic 2 1/8" cap sold at places like Home Depot is too small.
Any bright ideas on where to look for a cap or ideas to make one out of common materials? :confused3:
   / Looking for a Harbor Freight Pump Gas Cap #4
I recently purchased a 3" trash pump and it also has a threaded cap and a separate tank vent with a hose going to the carb or air cleaner. Must be EPA mandated. Not sure if mine has male or female threads.
I was looking for a replacement cap to modify like they do to get extended run times on Honda generators. This pump does have a fuel pump so I might just slip a fuel line into a gas jug and bypass the built in tank. Might be a temp option for you.
   / Looking for a Harbor Freight Pump Gas Cap #7
iu
   / Looking for a Harbor Freight Pump Gas Cap #8
That works, but they flare up, and taste bad when cooked, after you find your cap.
Bruce
   / Looking for a Harbor Freight Pump Gas Cap #9
maybe a 2-1/4 npt black iron pipe fitting ? or plastic/pvc npt fitting?
or even brass my bus uses one about 2-3" in dia
I recently purchased a 3" trash pump and it also has a threaded cap and a separate tank vent with a hose going to the carb or air cleaner. Must be EPA mandated. Not sure if mine has male or female threads. I was looking for a replacement cap to modify like they do to get extended run times on Honda generators. This pump does have a fuel pump so I might just slip a fuel line into a gas jug and bypass the built in tank. Might be a temp option for you.
This pump had a similar system and the pump would die unless I left the cap a little loose. That was why it vibrated loose and melted.
