Looking for a Snow Blade for BX25
   / Looking for a Snow Blade for BX25 #1
stuarth
Northern Ohio
Kubota BX2670
I am looking to add a snow blade with power angle to my new BX25 and am wondering if the BX2763A and the quick hitch are the same from the BX2200's, BX2230's, BX23's and BX24's. Looking for a slightly used but good condition blade close to Northern Ohio if it's the same as the other models.
   / Looking for a Snow Blade for BX25 #2
Doesn't look like it. According to my listing, the BX2200's, BX23, BX24, BX2350 use the BX2751 Quick hitch.
The BX2763A must be special for the newer BX25 and BX2660 series I'm guessing.
Not sure what the difference between the two might be and who knows, maybe it's a slight modification you can do to make it work.
   / Looking for a Snow Blade for BX25 #3
I had BX 2230 with quick hitch and 60" front blade. Kept blade and hitch when going to BX 2660. They will fit the BX 2350 & 2660 with out modification.
   / Looking for a Snow Blade for BX25 #4
Well there you go, looks like it will work after all. Thanks Flatlander.
Thanks for the advise, now I just need to find one!
   / Looking for a Snow Blade for BX25 #6
Tim what is the model number for the mounting frame? By any chance do you have a copy of the mount manual. I have an L2072 but cannot locate the mid frame mounting manual.
Wayne
   / Looking for a Snow Blade for BX25 #7
Wayne
The male quick hitch and subframe is model #BX2751. Yes, I have the Manual.
   / Looking for a Snow Blade for BX25 #8
Staurt, I have a Deere 66 inch blade with hyd. angle that you may be able to be adapted to the Kubota quick hitch with some modification, if you want to take on the project. I'm in the Northern Panhandle of WV and would deliver for .80 cents a loaded mile. You can look at the TBN classifieds in the attachment section to get more info or email me a dirtworksequip@aol.com if you need more pics or info.
Sincerely, Dirt
   / Looking for a Snow Blade for BX25 #9
*I just need to find one!
I have the BX2763A 60'' blade and the quick hitch with power lift and power angle on my BX1500 and it will also fit and work on my BX23.
I put it on the BX1500 so I don't have to take the FEL off the BX23.
L . B .
*check with your dealer.
   / Looking for a Snow Blade for BX25 #10
*The BX2763A must be special for the newer BX25 and BX2660 series I'm guessing.
There are only 2 front blades available and they are available for all of the BXs.
A=60'' with power lift and power angle. The BX2763A
B=54'' with power lift and manual angle.
All you have to do is chose which one you want.
I was there and done that a year ago this month.
*Nope it's not special for the newer BX25 and BX2660 series.
It's for all the BX Models. Ask the guy who has one on his BX1500.
I had a BX 2230 with quick hitch and 60" front blade. Kept blade and hitch when going to BX 2660.
1*They will fit the BX 2350 & 2660 with out modification.
*They will also fit all the rest of the BX models.
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
Auger (A50860)
Auger (A50860)
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2012 Dodge Grand Caravan Van (A48082)
2012 Dodge Grand...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
