Loud Popping from Excavator Track
   / Loud Popping from Excavator Track #1
Dataway
Greenfield TN
Ford 1715, BX2200
I've got a new KX040 with about 20 hours on it, half a dozen times now the tracks have made a load popping .. which I assume is a mis-alignment on the sprocket as it follows a tight turn. I try to exercise good practice and keep both tracks moving when turning. I think I know the cause, the question is, is it relatively normal or indicative of a problem. So, should I improve my turning technique, or worry about the machine?
   / Loud Popping from Excavator Track #2
I have a smaller Kubota, the KX018, and occasionally I hear what sounds like a popping, but I think it is a small rock or debris getting busted by the tracks.
   / Loud Popping from Excavator Track #4
Screen Shot 2024-08-26 at 11.45.43 AM.pngI did, was okay and within the measurements.
   / Loud Popping from Excavator Track #5
I have a little KX008-3 and mine does the same thing. I think it's usually sticks or something out in the woods.
   / Loud Popping from Excavator Track #6
Mine does it also, mostly when I pickup a pick of gravel or stone in the track. It is a noticeable pop!
   / Loud Popping from Excavator Track #7
my Bobcat E32 does this all the time worse when I have been in the gravel and rotated, try turning the bucket 90degrees and lift one side of he machine then run the tracks on that side and see if you have rocks or debris in the track, when clear does the popping stop?
   / Loud Popping from Excavator Track #8
Mine’s the same, in my case it’s a rock, dirt or stick, I’ve learned to reverse that track to try to eject the debris. Make sure you tracks are tight or you could throw one when this happens. Mine doesn’t like gravel turns at all.
   / Loud Popping from Excavator Track #9
mine does it on one side. I thought something boke. I have a takeuchi TB235. Doesn't do it all the time but when it does, it's loud
I never thought about the fact that it could be debris scooped into the tracks when it's sliding sideways during pivot.
In my case it could be chucks of hard clay soil, I mean stuff so hard you'd think it was a rock.
It only does it once ... I'll make a pivot using only one track, then move a few feet forward and the track that was not moving during the pivot will making the popping noise, just once, then won't do it again unless I do a sizeable pivot without one of the tracks moving. Sounds a lot like one of the sprocket teeth "popping" into place on the track.
I'll check my manual again ... but I think it recommends keeping both tracks moving when pivoting.
Mini Dingo Tree Scoop (A45788)
Mini Dingo Tree...
NEW 2.4 HP HORIZONTAL ENGINE NEW SUPPORT EQUIPMENT (A40023)
NEW 2.4 HP...
2017 MOROOKA MST 150”VD (A45046)
2017 MOROOKA MST...
2015 OVERLAND TANK DOT 412 ACID TRAILER (A45333)
2015 OVERLAND TANK...
66in Bucket (A45788)
2018 GMC SIERRA 1500 (A45333)
2018 GMC SIERRA...
