sea2summit
Elite Member
425lb forks? That can’t be right on that tractor.425 lbs
I have had different experiences. Especially if carrying a load in the FEL up a grade.every HST tractor I have owned or driven would easily spin the tires in low range even on good traction.
Yep, half the time I’ve got a dog asleep in the cab covering all the pedals.Makes no sense to me. HST is right leg / foot actuated. Gear drive with a hydraulic shuttle is left hand left foot actuated and you can never expect good gradeability with an HST in the first place..... and, I hardly ever use the clutch pedal anyway, most times I use the column mounted shuttle lever.
Yes, those brakes were designed before HST was a thingThe pedal pressure is lighter than my truck is lol. I was going for a gear drive one for the extra power. But the amount of front end loader work and grading we was doing hst made more sense. Plus the safety factor on these hills out weighted getting a gear drive even at the cost of quieter and stronger. Do you still retain the cutting brakes with the GST? I’m sure glad I had them today in the woods. Some tight spots needed it lol.
Something doesn't seem right with your machine. I've never wished I had more power with my L5740 and it's only 17 more hp than yours on a slightly heavier tractor. It will easily run out of traction in medium high range before it loses power, even with studded chains on the rear. I can honestly say I've never even used low range for anything. My rears are loaded and if anything I wish I had more weight for skidding logs. All my log skidding is done in medium range (combination of low and high on the column) in the woods, depending on grade. It's mostly medium high except for a couple really steep pulls coming out of creek beds. Once I get out to the field I'm able to shift into high-low range with a decent uphill grade. I run it the same way pulling a 6x8 trailer heaped with firewood. Hopefully your dealer can figure out what the issue is and correct it for you.
Be careful what you wish for, it’s constant criticism about everything you do. Like how long it takes you to hook up a PTO shaft.Now that would be great having my dog there.
