M5700 not throttling down
   / M5700 not throttling down #1
bigtater
Southeast, TN
bota 5700
Just wondering if anyone else has had this issue. When I raise my rpm's up with either the foot throttle when I try to go back to idle or a lower rpms it drops a few 100 rpms but doesnt go all the way back. I can reach around to where the hand and foot throttle meet, push one of the parts there up and it goes to where its suppossed to and stays. I adjusted the linkage on the foot pedal thinking it wasnt allowing it to go back to idle position that didnt help. I have sprayed the outside of the assembly with oil to see if it might be a lubrication issue. I thought about taking the bolt that hold the assembly together but its a has a lock nut on it. I was wondering also if there was suppossed to be an external spring on the injector pump to pull it back. I cant remember seeing one on there but its been a while since I've looked.
   / M5700 not throttling down #2
I believe there will be a return spring on the foot petal but not on the hand throttle lever.
Wherever you set the hand lever, that will be the lowest the RPM will drop when you take your foot off the foot petal....
So the spring on the foot pedal shaft under floor returns the throttle rod?
Spring ONLY returns the foot linkage... the actual throttle rod is set able using the hand operated throttle leaver. ... that must be manually returned to idle . KennyV
I know the hand lever controls the lower limit rpms. When you pull the hand lever down the rpm's dont drop.
   / M5700 not throttling down #6
I am having the same issue right now and was curious to see if you ever were able to get this fixed and what was the ultimate cause.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2003 John Deere 1600 Turbo Ride On Mower (A50860)
2003 John Deere...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Ferris IS2100Z Zero Turn Mower (A50860)
Ferris IS2100Z...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
Miscellaneous Crate of Parts (A48083)
Miscellaneous...
