I have a 4025 that has less than 300 hours on it. That said, I've only owned it for about 2 runtime hours of that (haven't really started using it regular yet). When I test drove the tractor, everything worked fine, shifted nicely, no issues.
Last week, I noticed that when I try to go into gear, it was grinding a bit, and has gotten worse. This is with the clutch half-depressed only. PTO worked fine -- engages and disengages with no issues -- with the clutch all the way down as it should.
This week, the gears grind even with the clutch fully depressed, but the PTO still works fine.
To be more specific, as I recall:
I tried adjusting the clutch adjustment, but it was about at the end of its travel - any less and the clutch stops engaging at all.
Given it's impacting both gear selector and high-low, I thought maybe it's an issue with the tractor hydraulic fluid level as well. However, the fluid seems to be between the two marks at the bottom of the dipstick. Is it right that there are just two little marks at the bottom of the stick about 1/4" apart? I want to be sure I'm reading this correctly.
If it's not the THF, am I looking at a clutch issue or transmission issue?
I'm at a loss and don't want to damage the gears, but it's to the point where I need to use the tractor as well. Not to mention, high gears are almost impossible to use without some real grinding. At least I found a means to get it in gear with little to no grinding for now, but this is not ideal unless I need to "set it and forget it" for something like brush hogging.
Thanks for the help and direction!
Chris
- If both the high-low and gear selector are in neutral and I depress the clutch (half-way or full), I can put the tractor into any gear, but when I go to put the high-low in either position after selecting a gear, it grinds pretty bad. High is worse than low FWIW.
- If both are in neutral, if I start with the high-low, it grinds unless I work very quickly, and then when I go to the gear selector, those gears grind as well.
- If both are in neutral, I can put both the high-low and gear selector where I want at the same time and little to no grinding if I do so very quickly.
- If I'm working in a gear and put the clutch in to switch gears only, then if I shift very quickly, little to no grinding, but after a few seconds with the clutch in, it grinds going into any other gear.
- If I'm working in a gear, I can't switch low to high without grinding.
Chris
