Mahindra starter wiring [helP]!!
   / Mahindra starter wiring [helP]!! #11
Good luck if you are trying to find the 26 series wiring diagram. I wish Mahindra's website was a good as the tractors. I have been to the John Deere site, and it is vastly superior to Mahindra.
   / Mahindra starter wiring [helP]!! #12
You can find virtually any answer you want on the Mahindra site. The variety of answers to a given question is awesome.
larry
   / Mahindra starter wiring [helP]!! #13
larry
Larry, the drop down list for wiring diagrams does not contain the 15 series. You can see the operators manual, but there isn't a diagram - unless I overlooked it.
And, the green tractor site is mucho better.
   / Mahindra starter wiring [helP]!! #14
I thinks the flavor of my post didnt come thru. ;)
larry
   / Mahindra starter wiring [helP]!! #15
I not sure if this will help or not, the circuit diagram I have for my 2815 only shows 4 wires to starter, not sure why they would have 5 wires.Unless it was for a add on device and they just got power from the starter location.
   / Mahindra starter wiring [helP]!! #16
That fifth wire may be to "Pull" the fuel solenoid on. Try hooking it to the starter activation post see if it starts and stays running when you let off on the key.
   / Mahindra starter wiring [helP]!! #17
I maybe wrong but it seems to me that both tractors are using the same engine and I'd think that the starter system would be the same or real close.
To help can you look at the wires and tell me what color combination's each wire has. Maybe through elimination and my manual we can figure out where
they all go.
   / Mahindra starter wiring [helP]!! #18
Sorry, but I don't see 5 wires.
This is just a note to say that the pics posted by mboulais do indeed show the 5 wires on the Mahindra 15 and 16 series tractors. I have a 2816 with a starter that is identical to the pics posted. You can't easily see the black wire from the starter to the inner terminal of the solenoid or the main battery lead under the rubber boot to the outer terminal. So, the outer terminal has the main lead from the batter and a black wire. The inner terminal has the black wire to the starter and the red wire. Then the wire with the spade connector is in the middle. Hope this helps anyone checking this thread with starter problems. My starter went out with only 170 hrs on the meter.
2021 John Deere 333G (A55272)
2021 John Deere...
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
DEWALT CHOP SAW (A58374)
DEWALT CHOP SAW...
20 BLADE DISC HARROW, 3PT (A52708)
20 BLADE DISC...
2015 Peterbilt 365 Quad Axle Altec AC45-127S 45 Ton Crane Truck (A55973)
2015 Peterbilt 365...
