Massey 2310 backhoe not working right
   / Massey 2310 backhoe not working right #1
Ryanhurley2017
Massey Ferguson 2310
I installed a loader valve and my backhoe attachment barley moves loader works perfect
   / Massey 2310 backhoe not working right #2
Did you used the right Power Beyond sleeve for the new valve? From the pictures, it doesn't look to be the right fitting and it doesn't even thread all the way in.
The last picture is the old valve, I bought a regular 1/2 to 3/8 fitting and connected it, is there a special sleeve and what port is power beyond? Also what hose coming from my backhoe should be connected to the power beyond
   / Massey 2310 backhoe not working right #5
I was speaking about first valve. Yes, there is a special fitting/sleeve for the power beyond port that will there feed the backhoe. The other line, just besides the power beyond line, will go to the tank/transmission housing. The other line comes from the Pump and goes on the P port of the new valve.
The valve is labeled with P, T and N. P is Pressure in (from pump), T is Tank and N is the power beyond.
The power beyond sleeve looks like this. It's also specific to that brand of valve, so you may need to see if the seller has the proper sleeve available.
Does all the fittings need o rings? None of them are leaking
   / Massey 2310 backhoe not working right #7
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2006 Nissan Xterra SUV (A55853)
2006 Nissan Xterra...
210 GALLON PORTABLE DIESEL FUEL TANK (A57192)
210 GALLON...
WB 36" PIN ON DITCHER BUCKET (A52707)
WB 36" PIN ON...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
