Winches Massey 2606h
   / Massey 2606h #1
BEAGLES
Holland, NY
Massey 2606H
Cleaning up a site for a future log cabin. Got a few logs and fire wood from the top.
   / Massey 2606h
   / Massey 2606h #4
that a 3pt pto driven winch on back?
never personally seen one so was looking at it.
   / Massey 2606h #5
Yeah, verily ! You need a little more air in your front tires for that stuff ! My grapple is pretty similar to yours. Mine is on a DL250 loader and MF2660HD tractor. Very versatile & found myself leaving it on more so than the bucket.
   / Massey 2606h #6
What is that dozer-like grader blade on the 3pt? Have not seen one of those before.
   / Massey 2606h #7
why I asked if was winch, pulling would plant that end into ground.
edit: did not see the farmi decal before
  • Good Post
Reactions: JWR
   / Massey 2606h #9
I’m having a problem with installing a 3rd function on my 2607. At 1st I was blowing the seals on the grapple and then I rearranged the the lines to come off the lines feeding the rear remotes because it has a regulator but it doesn’t work unless the remote lever is engaged. Any way you could send some pictures of how the hoses are connected? I would really appreciate it.
   / Massey 2606h #10
This is redundant with a new thread you posted on your 2607 problem. I replied THERE not here.
UNUSED 30PCS Heavy Duty Hinges (A50860)
UNUSED 30PCS Heavy...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
1041 (A50459)
1041 (A50459)
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
