massey ferguson 2300
   / massey ferguson 2300
thanks, I will google it to find how to quick disconnect it. the person I purchased it from was moving and was still looking for the manuals for it. ray, if you have the dimensions of the two steel bars, I can fabricate the to whatever. our sister company is a steel warehouse. thanks again guys for all the information. ray I know you said your tractor is in semi retirement, always garaged, that's how I am with everything. the one I got it from, left it outside, and it does have some battle scars. I have the hood, grill, etc off, knocking out the diings, little puddy and will paint her up. it will be in the garage from now on. probably use the john deere 445 for plowing. I am going to weld brackets on the massey, so I can put the plow either on the deere or massey. hoping the joy stick will run both functions on the plow
ray, you talked about two bars that the loader rest on. do you have the dimensions? our sister company is a steel warehouse and I can buy anything I need from them. I will also make two brackets and weld on the front of the guard for a plow. I have one for my 445 john deere and I am hoping that the joystick will work both function for the blade. I will try it before welding on the brackets
   / massey ferguson 2300 #13
The bars should be pinned to the inside of the main loader frame. Near the ends of the arms, by the bucket.
They are long pieces of steel painted matte black. They look like they are doing something, but they are just clipped there for storage.
There is slightly more to them than just flat stock.
I will have to get out there, measure and photograph them. Not sure when I can right now, but if you are sure yours are not there, let me know and I will.
How about attaching the plow to the loader, or the bucket?
   / massey ferguson 2300 #14
Phil, here are some shots of my 2310. To remove the FEL, I use a flat 4-wheel dolly: lower the bucket onto it at a slight angle outward; then, with tractor shut down, move the joystick so it settles down flat on the dolly and on its two "feet" that Ray was talking about. At that point, the pins will slide right out. I then re-start the tractor and move the joystick forward, IIRC, and the two arms will rotate forward and away from the frame on the tractor.
At that point, I relieve pressure and disconnect the hydraulic lines, then lift the bucket arms, one at a time, forward and out of their sockets. Then the tractor can be moved rearward, away from the FEL, and I can then, by standing between and lifting on both the hydraulic rams at the same time, maneuver the FEL into position for storage, rolling it along on the dolly. Just don't forget to put the two feet down at the beginning of the procedure! Sorry, but it looks like the pics are in reverse order.
Hope this helps. ijk
   / massey ferguson 2300 #15
Thanks Irv.
thanks ray and irv, the pictures help out alot. ray, i would just need the length of them, i can fabricate them and add feet to the bottom and punch holes in them. i do have the brackets on the loader so i can get my hole dimensions from that. when i get the front back together i will take some pictures of mine, i will paint the floor area next. too bad the guy i got it from just left it outside and really didn't take great care of it. i found a massey dealer about an hour away, he has the head light assembly coming in, that was also broke in two. either way its a great find and a little tlc and i think i have a winner here. thanks again guys
   / massey ferguson 2300 #17
Phil, are you saying your FEL doesn't have the black stand arms at all?? Here are some pics of the left arm; the two legs appear to be mirror images of each other. Total length is about 24-5/8", but as you can see there are a couple of angles and one twist in it at the bottom. Steel looks to be a solid 1/2" thick. Second pic is the semi-permanent clip that holds it in place at the (lower) hinge point, next to the last pic is the right leg, in its stowed position along the FEL lift arm.
irv,
i bought it used, those two arms were not on it. he said he never took off the loader, cutting grass with the loader on seems like a pain, but he didn't mind. just seems like the added weight that's not needed would add wear to the tires and front axle ( 4 wheel drive). i did notice some oil leakage under the right front axle, under the planetary gears, next to the wheel. i will have to look into that and see if there is a seal i can replace. thanks for the dimensions, i can get some 1/2'' flat stock from work and add feet to it.
i wished he took better care of it but i am sure i can fix anything that it will need. i am impressed with the way it is built, very beefy. seems most of the other sub compacts are just gloryfied lawn mowers. looking forward to tackle this project
   / massey ferguson 2300 #19
"…some oil leakage under the right front axle…" I haven't yet had that problem, but I've heard of it. And yes, there is a seal in there that can be replaced. If you search it, I know there's a good thread or two concerning that on this forum.
BTW, that rubber anti-rattle thing you see behind the top of the right leg came standard beginning with the 2400 series, but the 2300s never had them. I scrounged a couple from the dealer and glued them onto mine; they really do work.
If you think the tractor itself is beefy, you should try a side-by-side comparison of the backhoes on a Kubota sub-compact and the M-F version. Huge difference in the construction of the M-F units: far more robust, IMO. Also, if you're interested, the older Kubota BX series used a 900cc diesel where the M-F's is 1100cc. More power at a lower RPM, and more PTO HP than the age-comparable Kubotas. (I suppose these days they may be all about the same, however.) Those were some of the things that made me buy a M-F tractor, and I've been very happy with it.
i watched some of the comparisons on you tube, i was surprised kubota did so bad. my neighbor purchased a new kubota, i really liked it until i started reading and watching the comparisons. i have had three other masseys, always older ones, 1972 model 135, 1976 14 hp garden tractor with mower, tiller, blower, cab. kept that a couple years. also i had a 1972 massey snowmobile 440 cc. they only made the a few years, they make good tractors but not snowmobiles
i will hunt that down about the seal, i am sure it is down on fluid, i will need to ask the dealer what to use in it.
i see you lots of toys for your tractor, how does the tiller work? i am thinking with the heavier tractor, it would work well
again thanks for your help
phil
2016 Volvo EC220EL (A55272)
2016 Volvo EC220EL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A55973)
Okada OKB 304B...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
