Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #1
ladddn
The throttle shaft on top of the injection pump for my 135 Perkins diesel tractor is leaking. Can it be easily repaired installed on the tractor or does the pump have to be removed for repair? This is the only problem with the pump and would like to stay away from having to remove the pump and retime everything. Any help would be greatly appreciated.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #2
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #4
I didn't post it on the forum as i don't have the permission
of the author, i would however gladly email it to anybody that
needs it.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #5
I would like a copy of this info also.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #7
I to have the same trouble with my 135 can you please help me.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #9
I have the same problem with my MF-135 tractor. It leaks around the Throttle shaft and a little around the fuel cutoff shaft. I'm new on this web site and don't understand it. need the e mail address of JJ jn BC so I can contact him.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #10
I have the same problem. Could you send me the same artical JJ in BC sent you.
Thanks
djksutton@embarqmail.com
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
