Hello. I have been trying hook up a temperature gauge I had lying around. It is a sunpro Buy Sunpro Style Line Mechanical Water/Oil Temperature Gauge - White CP8217 at Advance Auto Parts The problem I ran into was that the probes fitting screws into the original hole except when tightened down the gauges line moves inside of the fitting. So it seems that this gauge needs a adapter to be screwed into the original hole in the thermostat housing. I have three adapters but they are either too small or big.
I looked at buying a temperature gauge off ebay, but those gauges look just like the sunpro. And they list the adapter that comes with those gauges as 1/2 NPT. I have allready searched this site and I ran across a few posts to where people have bought a gauge and screwed it right in. But these same ones never addressed the line in the middle being stable and tight.
The post I looked at last night showed the fitting and probe and showed that the fitting would slide up and down just like this sunpro gauge.
My original probe seems to be solidly attached to the fitting, that would explain how it sealed in the 60's when built. Like who ever installed the gauge had to insert the probe, then tighten while simnutaneously turning gauge and line and fitting at the same time.
But the new gauges all show the fitting able to slide up and down the gauges line. I would call these places but all these customer services reps know is what is in the description of the gauges that they show online.
I also seen another post to where someone thought that maybe the thermostat housing temperature probe hole might have been drilled and tapped differently during different years. Mines appears to be 5/8 NPT. Or it is 5/8 UF.
Ok guys, tell me how yours is installed and what you did to install it. And what temp gauge you installed For MF 135 with the gas engine made during the 60's.
This gauge Massey Ferguson TO35 MF35 50 65 135 165 175 Temp Gauge | eBay looks like it needs a adapter.
This gauge ABC239 - Water Temperature Gauge is probably same way needing adapter.
I need first hand experience on this. I can take a pic of my original probe. It appears like the probe and nut are one unit hence not needing a adapter.
I thought about drilling a hole into into the water neck for a 1.4 adapter for the sunpro gauge. Then drill two 1/8 holes in the thermostat. That way it some water would bypass to it if it were stuck closed and overheating.
