4shorts
Elite Member
This winter it looks as if I'm going to be doing more snow clearing than normal. I got two more contracts and considering most of my seat time is in complete darkness I wanted to have the best possible lighting I could find. After much research I found a company in the US called Exploration Outfitters that sold the LED lighting I needed. I ordered up a 20" double row LED light bar and two 2" LED lights that I needed for Alley lights. When they arrived the first thing that impressed me was their quality. there was a card in each light stating they were tested before being shipped and that was great.
Now the next thing I had to do was design a light bar mount on the Kubota 5740 that would also accept the alley lights. I went with some 7/8th aluminum pipe. As you can see by the photo's I bent it to fit the contour of the cab. I machined end caps to give it a finished look. The next step was to mount it to the cab. I removed the mirrors so I wouldn't burn up the plastic bushings in the mounts then I made additional tabs to accept the light bar. I removed the roof and installed a new NAPA lighted switch in the head liner and ran the wiring. The 20' light will take 8 amps and the 2" will take.8 of an amp to run. The difference in lighting is astonishing. I'll let the photo's tell the rest of the story. Check out the link. if there's something you like email or call Matt and he'll set you up with some top quality lighting. I'll let the photo's tell the rest of the story but I will say I won't be in the dark this coming winter
Exploration Outfitters - Offroad/Overland & Public Safety Equipment
Exploration Outfitters - 20 Inch LED Lightbar
Exploration Outfitters - 2" LED Lights
Started off with this:
