Mulching kit for BX 2680
   / Mulching kit for BX 2680 #21
So, you BX owners, are you taking the kit off at certain times of the year? Is it doing a good job all seasons, or should I expect it to leave windrows in heavy grass? $400 cuts into a bagger or Cyclone Rake, so I'm trying to avoid eating the cost twice.
   / Mulching kit for BX 2680 #22
Sounds like that would be a pain in the arse and get old quickly!
We will keep in on all mowing season, if we have to mow a little often, it is better than sweeping the grass. Sometimes this year we have mowed after 5 days. We mow 10 acres with the bx and f2690 mowers, both with mulching kits on them. I would not take them off, to big of a pain in the a@@@@@@.
   / Mulching kit for BX 2680 #24
Well, I already knew the answer, but thought I'd better check.
Now, to figure if I should spend the $400 plus freight and try it, or just go with the bagger/rake I'll need in fall anyway.
What will you need the bagger/rake for this fall. I just mulch my leaves. I used a sweeper in the past, bought one 3 or 4 years ago, it just takes up space now. Good luck on whichever way you go.
   / Mulching kit for BX 2680 #26
I have three large sycamores and silver maples. The leaves are either so massive or thick, I can't mulch. It just kills my grass in spring.
   / Mulching kit for BX 2680 #27
I like that mulching puts the cut/nutrients back down rather than hauling it away.
   / Mulching kit for BX 2680 #28
I haven't raked leaves in over 20 years. I have lots of trees also. Try the mulcher on the leaves and maybe do a couple passes in different directions. Maybe even mow them every couple weeks during the dropping season. Maybe mow with deck a bit higher and then come back later and drop the deck down and chop them again. The mulcher will chop them to fine particles if it is working right and your BX2660 will have plenty of power to do it. Just keep in mind your chopping/mulching and not mowing grass so may need to slow down a bit in heaviest concentrations.
That is what I do.
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2019 GEHL RT105 SKID STEER (A52707)
2019 GEHL RT105...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
