MX5100 wheels/ tires fit on a L4150?
/ MX5100 wheels/ tires fit on a L4150? #1
jms13
Bronze Member
Kansas City MO
Ih 656,M95S,L4150
Does anyone know if the MX 5100 wheels/tires might fit on a a L4150.
I found the whole set for sale "AG tires" for $1400. Only have 257 hrs on them.
Was just wondering seems to me that the tires alone would be at least that much.
Thanks.
/ MX5100 wheels/ tires fit on a L4150? #2
Check the Bolt pattern if they are the same, then the wheels will fit...
Then check the front to rear ratio, if that is the same then the 4 wheel drive will work.
Divide the rolling circumference of the rear tires by the front circumference... do that for Both sets of tires.
The tire manufacturer will have rolling circumference on their web site. Or you can measure them if you are around their location. KennyV
/ MX5100 wheels/ tires fit on a L4150? #3
I checked tractordata.com for specs on your L4150 tires. It's a little confusing, but I don't think it'll work. Perhaps it'd help if you could post what size tires you actually have. I do know that my MX has 13.6x28 rears (which are listed as a possible size for your 4150). They were also available with 14.9x26s.
The problem I think will be the fronts. The MX tractors are only offered with 16" wheels, not 20" like your 4150.
/ MX5100 wheels/ tires fit on a L4150? #4
motownbrowne is on the money here - the controlling factor is the front/rear axle ratios that result in the correct traction difference in 4wd. The front tire contact is supposed to be going slightly faster (clawing a little). The MX5100 wheels might bolt up ok but I'm guessing the front rubber is not tall enough to provide the same "lead" when 4wd is engaged.
