buckeyefarmer
Epic Contributor
Transfer switch beside the meter ? And how will you get the top piece of siding in behind the top box?
We have 4” snow so far.
Dad was at ft sill about 80 yrs ago. View attachment 732931
Those barracks are the same kind of barracks i was in at Sheppard afb in 1971 for my tech school ! Thanks to your father for serving !Dad was at ft sill about 80 yrs ago. View attachment 732931
Looks like the transfer box and conduit are right on the siding seam ? Did you make sure that seam is sealed well ? That could be a problem down the road if the sealant fails ?I dont expect much accumulation of snow today. Too warm. It was 60 degrees yesterday and it is 34 right now.
Yesterday, I was getting the excavator running. I had previously had a fuel/water issue. After sitting for a long time. The water settled out and I was able to drain it off yesterday. I put the batteries back inAnd it started right up. I had been dreading it and expected to have to drain the fuel and take it to the recycling station. I will need that excavator because i need to get the well line in.
The electrician came and installed the panels and we are approved for early service. So I need to get ready for that. I have some dirt work I need to do behind the house, get that back area and slope the way I want it I plan to put in a retaining wall and want to get all my digging done before they trench for electric.
I never knew how beautiful a meter box could be.
We only get transfer switches if you are running a generator.Here in Tenn. its a straight run from the transformer vault to the meter, then the meter to the breaker box inside the building. No Transfer or cutoff switch involved.
If you need to kill the power going to the building how do you accomplish that?Here in Tenn. its a straight run from the transformer vault to the meter, then the meter to the breaker box inside the building. No Transfer or cutoff switch involved.
