My YM2200 Axle Seal Replacement W/Pictures
   / My YM2200 Axle Seal Replacement W/Pictures #11
Oh no !! It looks like the ym2500 we bought is set up just like that also.I never would have guessed it to be set up that much different and you couldn't just pull the hub. Now I know why the Rear looked as if it had been totaly disassembled on the Refurbishment Process.Now I'm glad the seals and gaskets appeared all replaced. But then again that is the only thing I don't care for is the setup of the PTO gears either.That is another reason I'm keeping and prefer the ym2000.:thumbsup:
Carey
   / My YM2200 Axle Seal Replacement W/Pictures #12
Yet 1 more reason I'm glad I have a YM2000(B):).
   / My YM2200 Axle Seal Replacement W/Pictures #13
I just seen this local.YM2200 for 5300.00 no ROP's in the Photo. I can get a YM2000 for 4500.00 with ROP'S. Boy the dealer sure is proud of that 2hp. I also would take the ROP's instead of the power steering anyday :ashamed: Crazy
Carey
   / My YM2200 Axle Seal Replacement W/Pictures #14
Carey
Power Steering on a YM2200?
Danny
   / My YM2200 Axle Seal Replacement W/Pictures #15
Went back to look for sure YES! PS. In upper case. It doesn't even have a FEL on IT.:confused2:
Carey
   / My YM2200 Axle Seal Replacement W/Pictures #16
I recently changed the rear axle seals in my Yanmar YM2200. When I searched for information on the internet on the seal change, I was not able to find any information. As a service to other YM2200 owners I took photographs of the whole process and created a nifty cross-sectional drawing of the axle housings.
The bearings are an interference fit on the axle and the bearing fit in the housing is an interference fit. As a result you will need a press to press the assembly apart and you will need to press it all back together after the seal is installed.
Here is a link to my website with pictures of the entire project:
YM2200 Axle Seals
Doug
Hi Doug thanks so much for taking time to document this repair. It's been a few years but it appears that the link above is no longer valid. Do you stil have this documentation stored and can you upload it to dropbox or google, or imgur?
   / My YM2200 Axle Seal Replacement W/Pictures #17
Cannot access the YM2200 Axle Seals photos. Really hope that someone can report them.
   / My YM2200 Axle Seal Replacement W/Pictures #20
Not sure if this will be of any help but I wrote up a how to on replacing the axle seals on my YM1601D. You can see that here: Yanmar Tractor Support Message Board
That is some great write-up. Not sure if I would ever need it, but I bet 100% someone will need it in a dire need. As I went through the how-to, at first I thought, that trans-axle set of gears looks nice and clean. Then near the bottom you had really made them clean.
Nice touch showing where to put the grease and the hint on the dog-gears.
1997 Dorsey 45' Aluminum Citrus Trailer (A57148)
1997 Dorsey 45'...
2019 PETERBILT 389 DAY CAB (INOPERABLE) (A58214)
2019 PETERBILT 389...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
