Need Cub Cadet Control Valve with Power Beyond
   / Need Cub Cadet Control Valve with Power Beyond #1
69800
Idaho
Cub Cadet 2000 series 2011
PROBLEM SOLVED. FOUND VALVE
I have a 1999 Cub Cadet 7265 with a 417 loader. My control valve float balls are corroded and dirty. The hydraulic shop cannot find the parts to repair it so I am trying to find a replacement valve. Mine has in and out hoses on the bottom. and a power beyond out the front. (its a compact verticle type single lever joystick)The unit is on the right side of the tractor so the 4 hydraulic lines are on the left side. I see some replacements but none set up quite like mine with power beyond. Can anyone point me in the right direction?
Thanks in advance.
Mark
2 spool
open center
2133 psi
7.8 gpm pump flow
3.5 gmp steering flow
cub cadet part number wm-34-6100p
loader model 417 #590-417-100 serial 13971
   / Need Cub Cadet Control Valve with Power Beyond #2
Welcome to TBN
Have you checked places such as Surplus Center or Bailey Hyd's for a control valve? I will guess that Cub Cadet doesn't build the valve in question but outsources it. Even companies as large as JD outsources hyd components such as control valves
Thanks. I have not checke Bailey and will now. Rumor is it was built by Woods. I found one that looks sort of similar (Akon Amv502F Loader directional control valve) youtube.com/watch?v=tGzBiu9-XUs. I wish I could figure out the woods part number.
I cannot believe it but I found an OEM replacement at cubcadet-parts-direct. It was $550.00 but its the exact part. Thanks all
   / Need Cub Cadet Control Valve with Power Beyond #5
You could probably get similar valve for less than 1/2 of $550 from the other suppliers I mentioned. Oh well it's your $$$$
2011 Hyundai Equus Sedan (A48082)
2011 Hyundai Equus...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
1272 (A50490)
1272 (A50490)
2018 Chevrolet Tahoe SUV (A48082)
2018 Chevrolet...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
