NEED HELP IDENTIFYING
   / NEED HELP IDENTIFYING #1
cqlawncare
I have acquired this tiller for a friend.
Tiller Serial # 513521
Im trying to find anything about this tiller. I need to get parts for it. THANKS !!!!!
Where would the model # be located?
   / NEED HELP IDENTIFYING #5
My guess is it is a four speed model Horse with the 8 HP briggs engine.
I think we finally concluded in another thread here that the two speed models have two belts on the drive shaft and the four speed models have a single belt. The four speed models have a low/hi speed pulley arrangement--but only the single belt that you move back and forth to get the two extra speeds.
MTD bought Troy Bilt and will have the manuals and parts lists on their website.
   / NEED HELP IDENTIFYING #6
It is definately a horse with a B&S 8hp non-electric start motor. Really makes no difference as to the year of manufacture as they are all pretty much the same. The thing to look for is as 2ManyRocks pointed out, the number of drive belts making it a 2 speed or 4. My bet with the 8 horse motor is that it is a 4 speed.
The other BIG difference is whether or not it is one of the PTO models. Does it have a lever on the lower left back side, on top of the transmission, that bascially turns the tines or PTO off and on?...........
Ok.......more later..........If you do some research here you will easily find manuals that cover the operation, maintenance, and use...........Good luck......Dennis
Rollback (A49461)
Rollback (A49461)
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
Fuel Tank (A50860)
Fuel Tank (A50860)
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
