3-Point Hitch need help
   / need help #1
cthompson
Mayflower AR
Mahindra 6110
I have A Mahindra 6110 got 220 hours the 3 point hitch is stuck all the way up i've tried the lock did not help
   / need help #2
Don't have your model tractor... but most tractors have a three point 'drop rate' valve [ or whatever you want to call it ] located usually down by your heels under the seat... or around the seat area. It is real easy to kick that thing a few times and shut the flow off so much that the three point will not go down. Just an idea....
   / need help #3
:welcome:
From Alabama.
   / need help #4
Pls call your dealer...hopefully with only 220 on the clock its still under complete warranty....ALSO, pls let us know what happens with the dealer...just in case. Good Luck. BobG in VA
   / need help #5
this..it's a large black knob. It took me a while before I realized that was my problem too. Unscrew it and the 3pt will drop.
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
377780 (A48837)
377780 (A48837)
