Backhoe Need Max PSI Setting for LW-8 Backhoe Relief Valve
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Hello gang,
It's been a long time ...
Today, I finally added a pressure gauge to my LW-8 Backhoe. You may remember that I got one from a friend, then fixed it all up and made a custom sub-frame for it to fit my 55HP Kama.
This is the name of the thread about it: "Diamond Shape Sub-Frame for LW-8 Backhoe" with lots of photos.
http://www.tractorbynet.com/forums/customization/188249-diamond-shape-sub-frame-lw.html
Anyway, here is my question ...
Does anybody know what the max PSI I should set the pressure relief valve on the LW-8?
It has self contained hydraulic system with a PTO mounted pump.
After installing the gauge, I found out I was getting only about 1,700psi !!
Right now I've adjusted the pressure relief valve to 2,250psi (same as the tractor hydraulics). However, I thought I remembered reading that the LW-8 and other Jinma backhoes have a higher relief setting than that? Maybe I'm wrong, but it doesn't hurt to ask all you experts out there.
If you want to see some photos of the gauge mod, I can take some tomorrow and post them.
Thank you,
Rob-
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #2
I don't have a technical figure for you Rob, but suggest you check the pressure rating that's marked on the hoses/cylinders/controller. It would seem logical to set the relief valve to at least 10% below the potentially weakest link.
//greg//
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #3
Don't have specs for LW-8... FWIW, I believe my HW-03 is rated the same as my Jinma 284 tractor(looks like the same pump) at 16 MPa max, which converts to 2320 PSI... I think I set mine(loader and BH) around 2250 also...
Of course we want to see pics of your gauge mod... Your mods are always cool and very well done:)
Hi Greg and Ron, thanks for the replies.
I guess I will stick with the 2250PSI I have it set to now. Just dug an 80' long trench and had plenty of power. Below are some photos showing the new gauge from front and back. I fastened it to the rear of the control housing with clamps and a shock absorbent hose liner. I cut the pressure line in to the valve and inserted a "T". All the fittings are re-usable hose fittings with JIC 1/2" for the pressure line, and 3/8" going to the gauge.
Thank you,
Rob-
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #5
I set mine to 2350, so I think around 2300 is a good number.
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #6
Excellent work Rob.
My LW-6 was set at 2,250, as is my LiTW BH7600. And FWIW, My Mustang skid steer remote hydraulics are also 2,250.
Footnote: I'm running a Prince HC7-A PTO pump for the backhoe, and coincidentally, the dozer hydraulics are also set at 2,250 psig.
Thanks guys,
Unfortunately, the riveted tag on the pump itself has been torn off so I was unable to identify the pump rating, which is why I posted the question. Anyway, the 2,250PSI setting seems to be comfortable for the hoe, so I will keep it there.
Thanks again,
Rob-
   / Need Max PSI Setting for LW-8 Backhoe Relief Valve #9
Didn't you originally have an Italian BH on that Mount?
Yes, but when I got this one, I moved the Nardi Backhoe over to Loretta's Jinma. Made a nice subframe similar to this one for that tractor.
