Snow Attachments Need snow removal advice
   / Need snow removal advice #11
Deep snow needs a blower. But blower takes longer than plow in most cases. I would vote for blower in your situation. Even then with BX it is going to be slow but faster than your current setukp.
   / Need snow removal advice #12
200" of snow between June and September?? Good grief man, how much snow do you get in the winter months??
   / Need snow removal advice #13
Although we don't see the amount of snow you do, I spent the first couple years with my tractor using the FEL (with a strip of oak bolted to the bottom to save my blacktop) and a rear blade. When we did have a relatively bad snow (for here) it was fine the first couple of times cleaning the driveway but the freeze/thawing of the drifts were a pain to deal with.
I invested in a front mount blower (I have problems with the concept of a rear mount) and of course that was the year we hardly got any snow. Even though my blower (60") wouldn't be considered big enough for your situation, it really blows the snow away from the driveway.
If I were in a situation where the snow was coming down hard and my goal was to stay ahead of it, I would go for a front mount or pull behind blower (do they make those?) so I could get it done quickly. IMHO Backing up to blow snow seems like it would slow a person down somewhat (I know it would me anyway).
For my driveway it is down once and back up and I'm done, but of course there is the road, some of the neighbors' driveways...what can I say, I'm having fun. :rolleyes:
Thanks for all the input, but still not sure a tractor blower will
work for me. I currently have driftbars on my 13hp Ariens that stand
4 1/2 high, but when the snow drifts & packs, it just drives right
under it. Have to use a show shovel to knock it down and go a few
more feet each time. Takes days, had a 9 footer took me a week before
I could get out to work. Plus with that weight must shovel the roof
and help elderly neighbors dig out.
Can you blow snow with blower up in the air on the 3pt and do it in
layers? Has anyone put extensions on the sides of your blower that high?
I can't imagine it safe to stand up and knock the snow down while
driving the tractor, or in the sitting position either.
My pto rated at 22hp, it will be less at my altitude and not work!
   / Need snow removal advice #15
I'd offer the idea to keep the FEL for scooping and lifting piles, and a rear-mount blower for blizzard blowing, Best of luck!
A big front blower sure would be great, but you may miss the ability to scoop chunks and move the stuff around.
I would wager you will be able to "learn us" all a lesson or two in snow removal after a winter or three.
In this case, it justifies a larger tractor and/or one of those double stacked snow-blowers you find out west where you are.
This is a perfect example of making sure to buy a unit big enough to handle the job....if there is such a thing, in this case.
Here is quick link showing several blower manufacturers, HP ratings, etc.
Edney Distributing Co., Inc. :: Farm Equipment Products Catalog Online
EDIT: i just realized the double-stacked units are very large, for tractors with much much greater HP. Looks like you could get away with a 50" wide and 24" tall blower?
(15 to 30 HP)
Good Luck, tell us what you get, and send pics of your first large snow, which I would guess might be weeks from now?
I said that backwards, its doesn't snow in July or august that it sticks.
So its 200-300 inches average per year sep thru jun (3 years ago had 8"
on june 30th) melted the same day
   / Need snow removal advice #17
You need bigger equipment for that kind of snow.
But, we all have budgets and we can all appreciate having to do, with what we have.
Your B7800 can handle a 50" PTO blower, and maybe even a 60" PTO blower.
Guessing t's going to be in the $1500 to $2k range, unless you find a decent used one.
An FEL and 60" Rear PTO Blower should be a 300% improvement over what your 13HP Ariens could do.
Do you have a heated CAB?
I would also be looking at one of those very seriously.
200" to 300" each season? Holy Moly!!
   / Need snow removal advice #18
We don't normally have the snowfall you do (although we did get 62" in one storm about 15 years ago), but I do have a B7800 with FEL and rear blower. I recommend that setup because of the flexibility, as SkunkWerx says. I have an old 72" blower, which the B7800 has tons of power to handle, but it is awkward to work with because it is so much wider than the tractor and the FEL bucket. As SkunkWerx says, 50" to 60" would be the way to go.
Yes, you can lift the blower and take off layers (as long as the snow isn't too packy, which leaves the packed wheel tracks almost impossible to remove). I used to have to do this on the first pass with this same blower on my previous tractor that did not have a live PTO.:eek:
And I also recommend a heated cab.:)
   / Need snow removal advice #19
Snow blowing is one of the reasons I got a new tractor. I have a 64 " rear blower and a front plow. 800 ft of roadway plus parking and turn round.
I had a 20 hp Ford 1320 for 11 years. One blower cut down the middle and then plow. blow back the edges if we had a lot of snow. Problem is bigger snow but less frequently. I can see that and it is the global warming prediction. Plus I hate getting up till it's all done coming down. So I got a 34 HP NH TC34DA. Loaded tires. See what happens this year. It's not so bad going backwards. Once I got a thermal sweat shirt with a hood. Also learn to watch the wind. Cab would take care of the whole thing I guess. Have to wait till I cannot stand the cold, few more years.
   / Need snow removal advice #20
I've been plowing with a truck forever,but just started blowing with a tractor last year. We get 120-240" per year. 1200' drive plus parking areas. Blowing is way better for us. Something to keep in mind is the banks are much shorter,or really non-existent,with blowing. With plowing,the banks pile up and the drive gets narrower. When those high wind snows come in,they fill up between the banks. When you have no banks like blowing leaves you with,there is much less snow deposited,therefore less to blow away. Front mount blowers are nice. Loader in front and blower in back is also neat. Two 200' drives,cab nice,but maybe not necessary. Tough choice for sure. Give blowing a chance,I think you'd like it.
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
JOHN DEERE 5083E TRACTOR (A57192)
JOHN DEERE 5083E...
UNUSED FUTURE D5T-34" HYD TILT BUCKET (A57193)
UNUSED FUTURE...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
