Need Trail Advice
   / Need Trail Advice #11
The more excavator you rent the easier the work.:thumbsup:
It may not hurt to have several swamp pads on hand for just in case. :)
   / Need Trail Advice #12
For moving the stumps, a thumb on the excavator will be a big help (and pretty essential for moving the pads.)
As for the swamp pads, agree they would be useful but I also suggest that you search youtube for "stuck excavator" to get an idea of what can go wrong even with experienced operators. There are some really interesting videos to watch:D
   / Need Trail Advice #13
I agree that this is the best solution. However, I'm not sure that equipment you will need to do it. A big excavator may be able to work it's way in, digging up clay from the side and creating a side drainage ditch as it goes.
I would think a problem with building a corduroy road would be how long would the wood last before rotting and failing?
Assuming the clay remains mostly moist a few inches from the surface, any corduroy structure buried in it is cut off from oxygen and will take a long time rotting. Also, if your problem sink-holes do not occur the full length of the trail you're putting in, why not just corduroy the problem areas?
   / Need Trail Advice
My problem is in the Spring, there is a lot of sitting water and it doesn't dry up until late June/July sometime so to get to the back of my property that is high and dry, I need to be able to get through this low area (approx. 10-12 acres). So I need to raise the whole trail and build some drainage ditches to keep the water away from the trail.
I'll be calling around this week for an excavator to rent.
   / Need Trail Advice #15
Now I'll suggest a completly different method. I've never done it but a member "Down Under" has a post on it from years back. Probably will not meet disposal codes though.:(
He bolted used tires together for the base pad and then hauled dirt on top.:D
The tires may also work for swamp pads.
   / Need Trail Advice #16
Have you seen the price of bolts lately??! :(
   / Need Trail Advice
Yes I have read his posts but I would not put tires into the ground on my property. And as you say, highly unlikely to meet disposal codes.
Tks for the idea though. I looked at some mats and they are not cheap!
   / Need Trail Advice #18
Only reason I mentioned mats is that if you get a "By The Hour" machine stuck it may cost before you get it unstuck.:)
1997 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1997 National RV...
UNUSED FUTURE CAT 301 ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
Pickup Truck Solid Bed Cover (A55852)
Pickup Truck Solid...
More info coming soon! (A55851)
More info coming...
(INOP) 2015 JEEP PATRIOT (A57192)
(INOP) 2015 JEEP...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
