Needing a transit/level.......any advice.
   / Needing a transit/level.......any advice. #31
Egon said:
If really looking for a cheap user friendly level find a clear glass mug with horizontal rings on it, fill with beverage of choice to one of the ring marks, hold steady so liquid is level on the ring mark and sight along the top of the liquid level. Works well if you can stand a little downhill.
I have used this method once when there were no levels on site. It worked well but due to having to keep the liquid/foam level even on a rim the beverage supply ran out and had to be refurbished. :D
In the picture the flat leveled area is under the trailer and a portion of the road is level but slopes downhill.
Pic looks a little blurry, must be looking through the bottom of the mug.
   / Needing a transit/level.......any advice. #32
I blamed it on the camera but you may be right!:D
   / Needing a transit/level.......any advice. #33
I have been looking for laser levels to, But know very little about them. If you get a DW73KD or the 71 model You can attach the detector to a 1 x 2 and raise and lower the stick to find the level spot, RIGHT? I want some thing for out side use, set concrete forms and inside for ceilings. Am I on the right track before I buy the wrong one.
Target cards? what is that?
   / Needing a transit/level.......any advice. #34
I have used just about every kind of transit and level and think the IR units that use a detector on your pole (audio and visual indicatioin) is the cat's meow but pricey.
If the greatest sight line is not more than a few hundred feet you can use a water level. Well, actually there is no limit to the distance possible with a water level but practical considerations like handling a lot of hose typically hold it to a few hundred feet. It will be slower and more cumbersome but it is (A) cheap (B) as or more accurate than any of the LASER units (C) easy to read in bright sun or at night with a small flashlight.
There are commercial water levels available, some with audio indicators. You can use a roll of small diameter plastic tubing or any number of garden hoses strung together. The only limit on max distance between your reference datum and a point you want to check is the length of the hose you are willing to string. There is no difference in accuracy between a commercial unit and a DIY version.
As we have all heard, water seeks its own level. You have a clear piece of tubing at each end of the water level so you can see the free surface of the water. When the motion damps out (a few seconds) the water at both ends of the run of hose is precisely the same elevation. You should be able to read the level to the nearest 0.1 inches at least. If you add dye (food coloring or whatever) to the water in the level it is easier to see and read quickly.
A water level can be set up and operated by a single individual. Of course, a helper, even with little or no experience would be a time saver but isn't required.
I find it convenient to mark plenty of grade stakes while using the level and then put it out of the way to play in the dirt. It is also is a super tool for concrete forming as it gives you a 20, 50, 100 ft or longer level with near perfect accuracy and dependability. It doesn't replace a standard spirit level for quick and easy approximations but stretching a string over50 ft or so will always have errors no matter how careful you are. A water level gives the same accuracy irrespective of the distance. It is as accurate as you can read the water level. For OLD eyes, use a magnifying glass for accuracey better than 0.1 inches.
It is a tradeoff between conventional looking tools with hitech prices and some clear plastic tubing and garden hoses that probably have more accuracy and cost less but are more cumbersome and slower to use. Let your wallet and conscious be your guide.
Pat
   / Needing a transit/level.......any advice. #35
It's easy to make a water level.
Buy a couple ft of clear plastic hose and a M/F pair of replacement couplers, assemble, and add to your existing hose.
   / Needing a transit/level.......any advice. #36
California, That is exactly what I did for one end. For the other end I used an RV water tank filler which is, not suprisingly, a clear tube on a female hose fitting. It is good to put some black vinyl electrical tape around the clear hoses to make it easy to read (calibration marks.)
There are various schemes for filling the hose with colored liquid but you can just fill the hose with water and put a few drops of food coloring in the open ends of the clear hoses. It is also good to have plugs for the open ends. I also use those cheap ball valves at both ends of the hose between the garden hose and the clear hose so I can secure the water before dragging the hose to a new location.
Pat
   / Needing a transit/level.......any advice. #37
You guys may be right about the water level, but I would also use one to setting a grade for concrete slabs, water drains and trenching depths with the BH. I do work alone most of the time.
   / Needing a transit/level.......any advice. #38
leeinmemphis,
Could you stake out a pond with it? Any info on the range? Thanks.
   / Needing a transit/level.......any advice. #39
The spectra i got is self leveling and had a option of ceiling mounts.You can find one at Whitecap under trimble manufactures .It also has a target you can buy to magnetic mount on a front loader or backhoe and shoot grade while on your tractor total one man operation.I got the LL300 unit they make better and one cheaper.
   / Needing a transit/level.......any advice. #40
If you want to buy one check out the pawn shops first.
They have any type you want. I bought an old really hefty one with tripod for $125. All the shops I visted had all types of laser and scopes. Bought the rod at Home Depot for $50.
For one-time use I would look into renting.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
John Deere tractor (A56857)
John Deere tractor...
2020 DRAGON ESP...
2017 Ford Taurus Sedan (A55853)
2017 Ford Taurus...
