Neutral safety switch on mf 2625
   / Neutral safety switch on mf 2625 #1
jcjdhicks
Hiddenite
2009 massey ferguson 2625
Where is the neutral safety switch located on a mf 2625 tractor. I went to crank my tractor and it want start, pro isn't engaged, in neutral, and battery is good. I've had it replace before under warranty but the dealer went out of business and the nearest one is 3 weeks behind and told me I could try replacing neutral safety switch. I'm assuming it is under the steering wheel on the left near lever to go forward or reverse . Any help would be greatly welcome
   / Neutral safety switch on mf 2625 #2
Is the range shifter (hi/lo) in neutral?
IIRC, the neutral start switch threads into the top of the transmission. You can remove the connector and short it out to test.
SDT
SDT
Yes the range shifter is where it usually is when I crank it. So the neutral safety switch threads into the top of the transmission, I will check it when I get home and see if that is my problem. I was also reading the manual and it said to replace my battery after three years but on the gauge it says it is fine, do I need to concern myself with that? It also said to service my transmission every 300 hours and I called my dealer and he said that it is usually after 700 hours, so I'm not sure.
Thanks for the replies in advance
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
550 Gallon Water / Chemical Tank (A50860)
550 Gallon Water /...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
