sunnyside360
Veteran Member
- Joined
- Aug 8, 2006
- Messages
- 1,561
- Location
- Central PA
- Tractor
- JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Just took delivery of new JD 3720 Cab and new 7 Iron 72'' mid-mount mower. According to mower Operator's Manual, the front upstop clearance is to be set to 1/8 inch in raised position by adjusting the two rear yokes. I've adjusted the yokes to where there is only about 1/2 inch of threads remaining and the upstop clearance is at 1-1/4 inches. The MMM s/n is M00072D331540. I'm wondering if this is the correct mower for this tractor as I cannot adjust/raise the deck to full up position. Or, does this mower just ride low to the ground when fully up? TIA for your help. JB
