Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,035
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My wife likes her cup of coffee. She's not a coffee snob....but likes a nice cup.
She's got a gal-pal. This gal has more cash than common sense?
Example: her mother passed. She took some of the inheritance and bought (cash) a $250,000 fancy schmancy diamond ring as a momento to her mother. My jaw hit the ground on that one.
Be that as it may.... she had this coffee machine. My wife was over and the gal was going to toss it. I understand she said something similar to "I don't even know if it works"
My wife said "I'll take it!" so they tossed it into her car. After all, her husband can "fix anything" (ha)
A couple of things about this thing annoy me.
1. Very difficult to find/obtain a schematic of it unless you want to buy one for (something like) $40.00
2. Most of it is assembled with Torx screws. Fine, I have some Torx drivers
3. The back panel isn't put on with Torx screws....nope.... for the back panel, they used oval screws. Meaning, there is no slot, no Torx, no phillips, no nothing. What you see is essentially a small (looks round) nub. This nub is evidently slightly ovaled and the $25 or so special wrench you need to buy will take those buggers right out. Well, pffffffffffffft on that! I'm very patient and can use some needle nose pliers and a good grip.
Wife told me this is around $1,500 so I should go ahead & get the manual and special wrench.
I tell her bunk. I don't need a manual to take the silly thing apart. Once apart, I might need it to put it back together but until I get to that point, I'm not going to worry about it.
Cutting to the chase, it leaked like a sieve where the coffee spouts are.
Got it apart and what did I find? Right above the two spouts was a bunch (and I mean a bunch) of muck. Some assorted coffee grounds and other dried coffee goo that was basically plugging up the hole and causing the coffee to over flow. It still tended to hit the cup but, once the cup was removed, it would still slowly drain through the muck out the tips and make a mess.
So, got that muck cleaned up and.....still leaked.
Took it back apart and looked closer.
Seems there is a pressure regulator in there, much like you might have on a bottle of propane although this was about the size of a half dollar.
(does anyone remember those anymore!
So ordered a new regulator ($50) and it arrived. Slapped that bugger in and this thing is now (as her father would say) "dry as a chip"
She's now turning into a coffee freak saying that this thing makes coffee much much much better than her prior machine. She's using this thing several times a day verses the old one cup a day in the morning.
I get to feel good getting in there and diagnosing this mess of plumbing and we've only got $50 involved.
