New holland 3930?- where do you put in hydraulic fluid.
   / New holland 3930?- where do you put in hydraulic fluid. #1
AlbertC
Perry, GA
New holland 3930
I just changed the hydraulic filter on my 3930 for the first time since I bought it (used tractor) I probably lost a qt to half a gallon of fluid. I looked in the manual and can't find anywhere where it tells you where the refill is. I also can't find if there is a dipstick to check the fluid level.
Does anyone have a 3930 who can tell me where to refill the fluid and also tell me if there is a dipstick to check the fluid level.
Thanks, and yes I feel like a dipstick for having to ask this question!
   / New holland 3930?- where do you put in hydraulic fluid. #2
I'm thinking both are near the gear shift, been a while since I've been around one though.
   / New holland 3930?- where do you put in hydraulic fluid. #3
The rear end oil where the hydraulic filter draws from is checked by a dipstick from the back of the tractor on the LH side above the axle housing. Filler plugs are the 2 large plugs on top of the rear end behind the seat. If you have deluxe remotes, then the filler is on a tube sticking up behind the seat.
The transmission check is the large plug/dipstick on top of the transmission.
2008 CAT 305C (A53317)
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58214)
SKID STEER...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
