New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it?
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #11
Do your self a favor and stick with the Mahindra backhoe.
Last year we had one in the shop with a Woods subframe mounted backhoe with a cracked final/axle housing.
After looking at how Woods mounts their subframe as to how Mahindra's is mounted, you would choose the Mahindra.
Mahindra's subframe ties into the center housings of the tractor, as to the Woods just on the final housings out by the tires.
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #12
The Max 3Pt. lower links are attached to Aluminum Case covers, The case itself is iron and the load is spread out, but a hoe attached here is a lot of stress.
Try splainin that to the Mahindra warranty department but I don't think it's gonna fly very far. LOL It's in very clear black and white print. Put an aftermarket hoe on it and you're pretty much on your own, period.
We got a Woodmaxx backhoe. Haven't received it yet but should in a few weeks. We will look into building or adapting a frame mount.
In my research I found the Mahindra backhoe to be inferior in several aspects to alot of aftermarket backhoes.
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #15
Please specify. I've had both (a Mahindra and a Kelley) and was satisfied with each.
Mahindra dig reach, the one seat for both tractor and backhoe, PTO operated pump has more power.
Some even say the Mahindra backhoe has issues at the main pivot point for let to right. It apparently sometimes jams there?
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #17
Don't know about the hoe for the Max but my Mahindra hoe was made in the USA by Kansas Machine Works. So far I'm happy with it and I will not have any warranty issues. The only problem I did have was with the crappy install done by the distributor but that has all been taken care of under warranty and it didn't cost me one thin dime. If I have any hoe related failures for the next four or five years, it'll be on Mahindra's dime not mine.
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #18
There are bigger aftermarket backhoes and ones with more impressive specs, but the Mahindra backhoe is well balanced and the stress loads are spread out over the tractor. I like the Woods sub-frame mount backhoe also, I've not seen the same issues as Johnson Auto, but that is something to consider.
I think a backhoe with much more digging power than the factory Mahindra backhoe probably shouldn't be mounted on a Max26. Also we need to remember that the backhoe can only push down so hard and the tractor comes up rather than the bucket digging in. If a person needed a lot more capability in the backhoe department, he might want to consider a little bigger tractor, and that applies to any brand.
   / New Mahindra Max 26 XL owner, any good mods or aftermarket backhoes for it? #19
Don't suggest a 3pt backhoe. For starters, putting one on will void your warranty. You get what you pay for so get the backhoe made for the tractor as it includes a proper subframe and isn't as likely to damage your tractor.
I see a lot of talk about aftermarket or third party products voiding warranties but that isn't 100% true in the US. In order for your warranty to be voided the product you used would have to be the cause of the damage. If you add a 3pt backhoe and there is an unrelated problem then you have warranty coverage. That being said, don't use a 3pt backhoe. It will break your tractor and the damage will probably not be covered by warranty. If the manufacturer requires the use of a certain branded product to maintain your warranty then they must provide it to you for free.
15 USC 2302(c)
(c) Prohibition on conditions for written or implied warranty; waiver by Commission No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer痴 using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the Commission if
(1) the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and
(2) the Commission finds that such a waiver is in the public interest.
The Commission shall identify in the Federal Register, and permit public comment on, all applications for waiver of the prohibition of this subsection, and shall publish in the Federal Register its disposition of any such application, including the reasons therefor.
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
Year: 2008 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2008 Make...
2024 Case IH Patriot 4450 Sprayer (A53485)
2024 Case IH...
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
