New Style B7100 Rear Hubs
   / New Style B7100 Rear Hubs #1
mrwitty_1
Can someone lend info on the proper way to tighten the new style rear hub for the B7100 ? Do you just tighten the wedge looking bolt and is there a proper torque value ? Thanks In Advance..
   / New Style B7100 Rear Hubs #2
hi, yes i just tighten up the nut and bolt and that clamps up the wedges against the hex axle. I just do it up tight and it seems to work just fine, being tapered it tightens up much better than the old type. I also put a smear of copper ease on the mating surfaces to stop them sticking when I assemble the hubs. As a precaution, I would check that the bolt is still tight and the hubs tight on the axle after an hour or so's work, that way you can check if you have it tight enoug.
Mat
Thanks, that's what I did just tightened up the wedges and it seemed to snug right up.
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
KSI Conveyor (A51039)
2015 DODGE RAM...
2018 Chevrolet Impala Sedan (A48082)
2018 Chevrolet...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
Bolens G272 Tractor (A50860)
Bolens G272...
